Results 1 to 5 of 5
    Crank replacement/upgrade
    Hey, relatively new to the mountain biking scene and new to the DIY side of it. I was wondering what kind of specs I need to consider when replacing a crank?
    I currently have a Shimano M442 44/32/22 but would like to replace it with a 2010 Race Face Evolve crank. Would that work as a replacement?
    Bike is a 2008 Trek 6000.
    Thanks.
    The 2010 Race Face will be a total replacement and will include new external bearings So it will work just fine. You will need two different types of tools to replace it since your old crankset is a Square Taper bottom bracket. It may end up being cheaper to take it to a shop for the initial replacement should only cost about 25-30 dollars.
    You will need the following tools
    8mm Crank Bolt wrench.
    Crank Puller
    Pin Spinner (only if you old cranks are one key release)
    BB-19 Bottom bracket tool for the new cranks external BB.
    IMO I would take it to a shop first and just buy the BB-19 tool for further maintenance of the external BB, since you will never use the other tools again unless you have a lot of bikes with Square taper BB.
    *this is all assuming you don't already have the tools and that the new cranks are a external bearing BB.
    Thanks, it's exactly what I was looking for. I was planning on taking it in to a shop for the initial setup to make sure it's done properly.
    What about the length though? I see from Jenson's that it comes in 170mm and 175mm options? Why would I pick one over the other?
    Thanks.
    170mm is the most common length. 175mm might give you more leverage on climbs. I just used the same length that came on my old cranks (175mm) since it worked well for me. Do some searching on Google for crank arm length.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    21.6 % of inseam length (bike inseam) is your correct crankarm length , found here :
    velonews.competitor.com/2003/11/bikes-tech/...
