Results 1 to 3 of 3
Thread: crank removal
    Reputation: chidDONG's Avatar
    Mar 2005
    crank removal
    possibly a stupid questiong but here goes... I have an '03 Icon (trek house brand) crank on my bike. I need to remove the inner ring and to do this I need to remove the drive side crankarm. It appears that all that I need to accomplish this is the properly sized allen wrench. Is this the case? If so, is it normal threading?
    things are more like they are today than they ever were before
    boring blogs:
    racin rick dam nelsons
    links:
    Bikeman
    Salsa Cycles
    SRAM
    Panaracer
    Team BikeWood
    Reputation: Toxic Avenger's Avatar
    you'll need a crank puller
    Quote Originally Posted by chidDONG
    It's a little more complicated than that but not difficult. You'll need an allen wrench to remove the crank fixing bolts, but you'll also need a crank puller to remove the crank arms. The crank fixing bolts are threaded normally so you just turn them counter clockwise to remove them. You'll need the correct style crank puller depending on whether your bottom bracket has a square or splined bottom bracket. Park Tool's website has directions and a list of the correct tools. Start here:
    http://www.parktool.com/repair_help/FAQrCarm.shtml
    To replace the crank arm just line it up and re-attach it using the crank fixing bolts. One note -- after removing the crank fixing bolts be sure to remove any washers that are between the bolts and the crank before using the crank puller.
    Mar 2005
    cool. thanks for the help
    boring blogs:
    links:
    Bikeman
    Salsa Cycles
    SRAM
    Panaracer
  1. Disciples of trail work
    By General Coonskins in forum Oregon
    Last Post: 04-26-2004, 06:20 PM
  2. Disciples of Trail Work
    By General Coonskins in forum Singlespeed
    Last Post: 03-23-2004, 09:49 AM
  3. Disciples of Dirt-Oregon trail work
    By General Coonskins in forum Trail Building and Advocacy
    Last Post: 03-23-2004, 09:43 AM
  4. Disciples of Trail Work-Oregon
    By General Coonskins in forum Endurance XC Racing
    Last Post: 03-23-2004, 09:39 AM
  5. stripped crank arm removal
    By qtip in forum Singlespeed
    Last Post: 01-26-2004, 02:15 PM
