I'm trying to install a my set of FSA cranks to a Truvative BB. They've got the ISIS with the 10 splines. When I try to install either crank, it won't go on far enough to get the bolt through so it can be threaded in there. I've done everything from trying to hammer the crank arm on to using a long bolt with washers as a type of press and none of it is working. From everything I've read, I shouldn't need any special tools to do this, right? Are new BBs that hard to put cranks on? Any help would be great. Thanks.
