Results 1 to 3 of 3
    Crank GXP short spindle issue
    Just tried to install a new Canfield gxp crank on a bike. The new crank spindle length is 111mm.
    TOO SHORT
    Old spindle Sram X0 crank is 114mm.
    Length is measured from edge were crank meets drive seal to very end of crank shaft.
    Bottom bracket is pf92 no shims or spacers used.
    Canfield stated its made for 68/73 BB
    I thought all should be standard in regards to spindle length.
    Any info would be great.
    Thank You
    Randy
    Oct 2007
    I would contact Canfield. I noticed that the cranks come with a BB, so perhaps the cranks must be used with the included BB, which may be narrower than a typical BB. I also note that the crankset comes with a spindle spacer, make sure that it is not installed.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Crankset does include 68/73 bottom bracket. Since I have bottom bracket allready on bike a different style pf92 I disn't use it. I assumed crankset spindle length came in standard length 114mm. Im at a crossroad I could press spindle out and machine spindle or arm 3mm and make up difference.
    The crankset is unique in that it has 155mm crank arms and is direct chainring mount.
    Wife is 5'2" and has had knee issues and this was an option to try.
    Thx
  1. Replies: 4
    Last Post: 06-01-2016, 11:29 AM
  2. Sram XX1 BB30 Q Factor 168 - Short Spindle or Long Spindle?
    By Fastblack in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-12-2016, 03:29 AM
  3. Short or long spindle XX1 for Raijin?
    By verrocchio100 in forum 29er Components
    Last Post: 11-21-2015, 12:29 PM
  4. SRAM X9 driveside crank compatible with S1000 spindle/left crank?
    By Bathwater in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-06-2015, 08:33 PM
  5. Short spindle for Shimano XT/XTR pedals?
    By BTLS in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-01-2014, 10:33 AM
