Results 1 to 5 of 5
    Mar 2006
    crank arm stripped what now
    My race face evolve crankset has the pedal threads stripped on the drive side. Can I buy a rt side crank arm only (includes the chainring spider), or do i need to helicoil it.
    Reputation: Brewtality's Avatar
    I would go Heli coil first. Much cheaper than buying a new crank arm.
    Its all Shits and Giggles until somebody Giggles and Shits
    Chronic Hucker
    Feb 2007
    I had the same problem a few weeks ago. I took the arm into my lbs and they put a thread insert (helicoil) in for me, cost 11 bucks.
    Make Yourself
    enjoy the ride
    Reputation: misctwo's Avatar
    would using the helicoil make the threaded connection weaker?
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    Quote Originally Posted by misctwo
    It will actually make the connection stronger. A Boeing 747 comes from the factory with over 40,000 Heli-Coils installed as OEM equipment. It's the preferred method for installing a steel bolt in to an aluminum threaded hole.
