If you purchased the Cross Check complete, you can convert the Barcons to Top Mounts with Paul's Thumbies. Avid levers are for V-brakes, but Cane Creek, Paul's, Shimano, and Tektro all make flat bar Canti levers.
Because V-Brakes have longer arms that offer a huge mechanical advantage over cantilever and caliper brakes, the levers are designed to have about half the mechanical advantage of a canti lever...otherwise they would cause the brakes to lock up with the lightest touch. And because they are connected directly, they have a lineal pull ratio (basically 1:1) so they have to pull more cable. Because of this, putting V-brake levers on Canti brakes will allow you to place the pads far from the rims due to the amount of cable pulled, but they will have half the power.
The Avid SD7 is a v-brake lever, while dialing them so they pull the minimal cable (which also increases the mechanical advantage) makes them marginally suitable for canti brakes, they do not match the power that dedicated canti levers can provide.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
