Results 1 to 7 of 7
    nnn
    nnn is offline
    Reputation: nnn's Avatar
    Feb 2005
    Converting 8sp cassette to a 7sp
    Well I haven't been around for a long time.
    Anyway my question is, is it possible to convert an 8sp cassette to a 7sp by removing one sprocket and spacer, and perhaps using the 7sp spacers to use as a 7sp cassette ?
    I'm asknig because 7sp cassettes are rarely sold these days, but it would cost me an arm and a leg to convert (integrated shifting etc etc) and I'm more than happy with a 7sp setup.
    Reputation: GearHead's Avatar
    Dec 2004
    Quote Originally Posted by nnn
    The spacing of the cogs is slightly different, 8 speed uses 4.8 mm c-c cogs and 7 speed uses 5.0 mm c-c cogs.
    There is no added value to my participation - in fact, just more confusion.
    Chrome Toaster
    Reputation: Hecubus's Avatar
    I suppose its perfectly possible but would likely require quite a bit of work to get the right spacing. If you get a lower end cassette which are usually the kind with complete cogs that are riveted together you can drill out the rivets and loosen all the cogs. You'll need to replace the spacers in between each cog to get the right seperation. Standard Shimano H.G. 7 speed sprockets are 5.0 mm in seperation with each sprocket being 1.85mm thick and spacers 3.15mm. 8 speed HG is 4.8mm in seperation with 1.8mm sprockets. Spacers are 3.0mm.
    Ebo
    Ebo is offline
    You can easily find 7 spd cassettes on Ebay, Nashbar, Cambriabikes, Bikeman, AEbike, etc.
    Live 2 Ride
    Reputation: Kona0197's Avatar
    Quote Originally Posted by GearHead
    If that's true why is it I can run a 7 speed rapid fire shifter on a 8 speed cassette with NO ghost shifting?
    My Bike: '15 Trek FX 7.2
    My Blog: http://http://kona0197.wordpress.com/
    Dec 2004
    Quote Originally Posted by Kona0197
    I don't know, maybe you aren't very sensitive to bad shifting. I didn't make this up Shimano and SRAM did. Here is a link that goes through it in detail.
    http://sheldonbrown.com/k7.html
    Chrome Toaster
    Becuase the difference is quite small and derailleurs have a certain amount of tolerance for slop before you start to notice problems. You can get good enough shifting under some conditions but it will be hard to det ideal shifting over all setups.
