Results 1 to 3 of 3
    Reputation: broncbuster's Avatar
    conversion / external bb bearings to 3 piece crank
    Has anybody converted their external bb bearings to 3 piece crank?
    Or know if it is possible?
    I would say external bb bearings are a stable set up and at slower speeds they are fine but seem to slow after a certain speed. Not to happy with the external bb bearing related problems either and literally think they are a drag!
    I am not looking to start a debate about his just curious if anyone else has done this or feels the same. Currently using FSA Megaexo. Thanks!
    Chrome Toaster
    Reputation: Hecubus's Avatar
    You need to remove the bottom bracket cups and just install a standard bottom bracket with matching arms. If by conversion you mean changing the integrated spindle cranks to use a conventional bottom bracket then the answer is NO. The spindle is a permanent member of the crank arm.
    Quote Originally Posted by Hecubus
    I meant to completely convert over to a three-piece crank / bb and new cranks.
