Results 1 to 7 of 7
    Oct 2007
    complete 29er bike, full suspension, rohloff
    7 NOV 07
    Sounds like you need to be pretty slick with tools to build a bike using a rohloff hub. Is anyone commercially building complete 29er full suspension bikes with a rohloff hub? I remember from my youth, when a ten speed bike was all the rage, that my Schwinn Sturmey Archer 3 speed hub was much the quicker shifter in any kind of variable terrain. The rapid shift with a much greater gear range is very appealing. More interested in a sturdy fun bike than a racer. Let's not completely break the bank either, please.
    Quote Originally Posted by kwolicki
    .....Is anyone commercially building complete 29er full suspension bikes with a rohloff hub?......
    Try Van Dessel
    Reviewer/Tester
    Reputation: Rainman's Avatar
    7 NOV 07
    Building a bike that uses a Rohloff hub is just like building a bike that uses a derailleur system.
    The fiddly bit is setting up the cables, apart from that, it's very easy to do.
    You can retro-fit a whole lot of bikes with a Rohloff Speedhub and doing it all yourself just isn't that hard. It's not rocket science...
    R.
    It is inevitable ...
    Oct 2007
    I greatly admire your confidence, and while being fairly dexterous (I am a surgeon), I am at a place in my life where between spending time diddling with the adjustments, and trying to keep the grease from under my fingernails (just looks bad) , I would prefer to have professional help. No way I would pretend to lace and true a wheel, any more than you would do a tonsillectomy. That is one of the great attractions of the Rohloff hub; it purportedly does not require lots of adjustment once installed correctly. I am understandably nervous that my LBS might have minimal to no experience with this, and there I am again without a support resource. Dreaming and planning, in mixed proportions. thanks.
    Reputation: glenzx's Avatar
    Quote Originally Posted by Rainman
    R.
    Not rocket science, just regular old geometry though!
    OP asked about a 29" FS with a Rohloff. To do it clean, without a tensioner, one needs a FS design that has zero chain growth i.e. - pivots around the BB - like the old Lenz design, or Deans:
    http://www.deanbikes.com/mountain/Ace%2029r/ace29.htm
    Enjoy.
    "It's better to regret something you HAVE done, than something you haven't..." -
    bump
    Well...? After all the great feedback - what's your decision?
    Sheepherder/Cat Herder Moderator
    Reputation: Visicypher's Avatar
    Bug Brett at Niner Bikes. He should be able to hook you up.
    ...building wherever they'll let me...
