Results 1 to 15 of 15
    lmw
    lmw is offline
    Apr 2013
    clicking sound when i pedal
    I recently took my bike in for a minor tune up, and now that I've got it back I notice a clicking sound when I pedal. the sound is only when I am pedaling, not coasting. also the clicking becomes more prevalent the harder i pedal, if i pedal lightly, no sound. I have no idea where this sound is coming from, it's also a fairly new bike (airborne goblin), any ideas?
    Worn cleats. Been there.
    Oops didn't finish reading. Maybe it's worn cleats if you're on the same ones from the previous bike.
    Check the front derailleur cable isn't hitting a crankarm.
    lmw
    lmw is offline
    Apr 2013
    that was my initial thought, but no its not. its odd to me that it only happens when my weight is applied
    Jan 2013
    Check to see if the cranks are firmly attached to bottom bracket. Check bottom bracket play in the BB shell. You might hear these things only when you're applying pressure.
    Re: clicking sound when i pedal
    Did you grease the pedals and torque them down?
    How are the pedals? Do they need service?
    http://Theclydeblog.org Big guy cycling product tester
    Are they crank brothers?
    Are you certain the click is coming from the pedal/crank area?
    Isolate the sound it could be your chain clicking against the cassette cogs because the cable is a little too tight and trying to shift to the next bigger cog.
    If it is the crank area follow the previous suggestions- ride with out being clipped in perhaps with street shoes.
    lmw
    lmw is offline
    Apr 2013
    no im not certain its coming from the pedal/crank area, its hard for me to pinpoint where the sound is coming but thats my hypothesis. I have platform pedals also btw
    Reputation: gmats's Avatar
    Apr 2005
    What is the frequency of the "clicking"? Is it once a revolution of the crank? Is it in all gears? Is it like a rapid "tick tick tick" sound?
    If it's once a revolution with the cranks, then it could be things like the front derailleur being hit as the crank goes around. Or, it could be the BB in the bottom bracket shell? Or, it could be the interface between the crank and the spindle. What kind of crankset/spindle do you have?
    If it's that "tick tick tick" kind of sound, it could be just a slight mis-alignment of the derailleur's jockey wheel and the cassette cog. This causes the chain to sort of bounce as it goes from the jockey wheel to the cassette's tooth. Adjustment for this is a mild adjustment of the barrel adjustment knob to either tighten or loosen the cable just a slight bit.
    Good luck with that, let us know what you find.
    Apr 2018
    if you crank backwards and you hear light constant rapid clicking sound, its normal. if you pedal and has a clicking sound like my bike, might be the derailleur pulley or mainly the derailleur. should give your bike a rest and spend time finding the problem. might sound ridiculous, but it can be an unfastened handle bar or seat post. or maybe clean the chain and gears.
    Reputation: sfgiantsfan's Avatar
    Dec 2010
    I hope it stopped clicking by now. Or maybe the dude is dead
    I'm sick of all the Irish stereotypes, as soon as I finish this beer I"m punching someone
    Purulento
    Late to the party, but even if your bike is not having any problems, this is a joy to read:
    Bicycle Bike Noises, Clicks, Ticks, Creaks, Clunks, Knocks Repair by Jim Langley
  1. Clicking Sound - Butcher
    By stevebrock in forum Santa Cruz
    Last Post: 11-29-2011, 04:30 PM
  2. Clicking Sound from Knucklebox
    By iRace559 in forum Diamondback
    Last Post: 09-19-2011, 02:44 PM
  3. Slight clicking sound ?
    By rickcin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-11-2011, 05:45 PM
  4. Clicking Sound - Mojo HD
    By aldeezy in forum Ibis
    Last Post: 04-05-2011, 07:08 PM
  5. Clicking sound from new rotor
    By SCR818 in forum Brake Time
    Last Post: 01-22-2011, 09:13 AM
Members who have read this thread: 34
