    Reputation: Dmytro's Avatar
    Nov 2003
    Cleaning/degreasing (new) SRAM Chains
    I got a PC-991. Is it necessary to do this (as with Shimano chains)? What should I use?
    bi-winning
    Reputation: rkj__'s Avatar
    Quote Originally Posted by Bloodfist
    Last i checked, sram reccomends you leave the waxy coating on.
    If you want to get it off, simple green will be a popular suggestion.
    I ran my chain fresh out of the box for 3-5 rides. The pre-applied stuff held up pretty well, and was quiet for quite a few km.
    Klydesdale
    Feb 2005
    Use it as it comes from the box. The inside of the chain will never be as clean or well-lubed as it it when it's new. If you ride in dry conditions and are concerned the coating on the outside will attract dust and grit, try running the chain through a rag lightly dampened with mineral spirits or some other solvent to clean the lube off the outside of the chain only.
    Nov 2003
    Great! No prep work needed for this item!
    ps: Powerlink rocks
