Results 1 to 9 of 9
    Chris King Bottom Bracket on Truvativ Cranks
    I have Truvativ cranks on my Nomad and my Truvativ Bottom Bracket is toast. I'd like to upgrade to either a Hope or Chris King BB, but Chris King doesn't make an adapter to fit the Truvativ cranks. My question is, does anyone know if the adapter that Hope makes will fit a Chris King BB correctly?
    Thanks,
    Chris
    did you call king, i thought they were making adapters that they sold as an option. that was about 1 month ago i talked to them.
    Former Bike Wrench
    You might consider the Enduro SRAM BB as well, it's US made if that is important.
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Hope makes an adapter and you would be better with it than a Truvativ specific CK BB, in case you swap afterwards...
    Edit : http://www.chainreactioncycles.com/M...?ModelID=26899
    Check out my SportTracks plugins for some training aid software.
    from what ck said, its not a specific bb. its an adapter that comes with a bb.
    It sounds like I need to give CK a call and see if they have an adapter that isn't showing up on their website.
    Thanks,
    Chris
    Rub it............
    Reputation: frdfandc's Avatar
    CK doesn't have an adapter. They have a SRAM specific BB.
    Reputation: crazy8's Avatar
    Bearing bushing
    I have this bushing. It was included with a Token BB so that it's compatible with SRAM, Truvitiv, Shimano, FSA and RF. Made to fit inside the L bearing from the inside of the cup.
    i ride bikez!!11!
    New for 2010 is the SRAM-compatible 24mm stepped axle configuration. The stepped axle Chris King bottom bracket makes use of a fit kit to match the crank axle to our standard cups and bearings but without use of chainline spacers. 125 grams..
    http://chrisking.com/bottombracket
Hot Deals
Contests
Latest Mountain Bike Articles
