Results 1 to 6 of 6
    TaS
    TaS is offline
    Check H and L stop when replacing a Hanger
    This is a big duh, but get in a hurry and it cost you a hanger and possibly more.
    I replaced a derailleur hanger that got damaged when drilling out the attaching bolt. Bolted on the new hanger, indexing hit on all points. I assumed (yes when a mistake follows it is an ASSuME) I was good to go.
    Not until looking for that next easiest gear, did I over shift and send the rear derailleur into the wheel. Bending the hanger.
    When I replaced the hanger, it became apparent that I over looked setting the limit screws during the previous install.
    Lesson learned.
    Have a Day
    Tom
    Littleton, Colorado
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by TaS View Post
    Lesson learned.
    Have a Day
    Tom
    Littleton, Colorado
    You need to check the alignment of the hanger before you remount the RD, too. They are rarely straight, even when new.
    mtbtires.com
    Reputation: gmats's Avatar
    Apr 2005
    Yes, all great advice.
    Checklist:
    1) Remove old hanger
    2) Check for frame damage
    3) Install new hanger
    4) Check alignment of new hanger
    5) Install, inspect derailleur and chain for damage
    6) Check limit screws of derailleur
    7) Check gear shifting with shifter.
    8) Ride bike up and down driveway to make sure when loaded, bike shifts cool.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by shiggy View Post
    you need to check the alignment of the hanger before you remount the rd, too. They are rarely straight, even when new.
    This!
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    all good advise above... hangers are almost never truly straight as they have all said...
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Jan 2011
    I feel your pain. I converted my drivetrain to a 1x9 a couple days ago. I wound up ahortening my chain and readjusting the rear derailleur and limit screws, thought i adjusted it correctly and went for a test ride. Im now in the market for a new hanger and derailleur. Im still not sure what i did wrong, i may have cut my chain too short..
  1. Stop
    By wgreaney in forum Beginner's Corner
    Last Post: 12-31-2012, 11:20 AM
  2. Looking for a Pro-Stop to IS adapter
    By Andy FitzGibbon in forum Brake Time
    Last Post: 12-21-2012, 08:30 PM
  3. Houndstooth Sportcoat - check; tie - check
    By mtbxplorer in forum Commuting
    Last Post: 04-22-2012, 08:16 PM
  4. Replies: 10
    Last Post: 03-07-2012, 10:12 AM
  5. Stop............
    By mechagouki in forum Vintage, Retro, Classic
    Last Post: 02-15-2011, 11:11 AM
