Results 1 to 11 of 11
    the catalan connection
    Reputation: What&son's Avatar
    Check this 136 mm q factor crankset
    hey! at last a narrow q- factor outboard crankset
    You know, if you want get things done.....
    Acording to the data the program gives at this point is 620 grams. Arms are not hollow. Axle is steel , arms and rings aluminium. Fixing bolt also aluminium. (bb and bolts not included)
    Its a kind of 960-970 hybrid. Most measurments are by guess (besides BCD and crank arm length, 175)
    You like it?
    "Blessed is the man who, having nothing to say, abstains from giving us wordly evidence of the fact." George Elliot
    Reputation: shiggy's Avatar
    Dec 1998
    Chainline?
    Chainring/stay clearance?
    Arm/stay clearance?
    Are you limited to using 1.5" tires?
    All of the above are higher priority to me than Q-factor.
    mtbtires.com
    I know, I know...
    None of this factors you mention have been considered.
    I was just moving forward for the feel for it. Maybe I draw something more elaborated soon
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    5 Arm Please
    4 arm spiders/chainrings are a joke.
    Uncle
    Reputation: Entrenador's Avatar
    Spindle options for Shimano?
    Hey Shig, wondering if you know of anyone that makes a shorter spindle for Shimano pedals -- don't need Ti, I just want to bring my knees in a bit. I just switched cranks from Stylos to XT760s and it feels weird & slow. Plenty of space between my shoes and the crank arms, so maybe I can run a shorter spindle on my M540s?
    Dec 1998
    Quote Originally Posted by 105millimetersofpleasure
    I am the wrong guy to ask. I have no idea and I don't care. Q-factor is a non-issue for me unless it is too narrow. I wear the finish off my crank arms and chainstays with my heels. If anything I want longer pedal spindles.
    mtbtires.com
    Quote Originally Posted by Shayne
    Why are they a joke?
    Dec 1998
    Quote Originally Posted by Whitebread
    Four-arm cranks created problems that did not exist before.
    Less support for the rings and the chainring bolts are more likely to loosen with use. This issue has shown itself many times with singlespeed use. The bolts loosen. One falls out. Half the ring is now totally unsupported and it folds.
    Sure, the bolts can loosen with 5 arms, too, but the ring is still supported enough to just wobble and warn you before it fails.
    It created a new ring "standard" nobody asked for, restricts the possible gearing range and has no advantages other than it may be slightly lighter and slightly cheaper to make.
    mtbtires.com
    O, now thats a good post.
    Music & Bikes
    Reputation: fokof's Avatar
    +1 for 5 arm 94mm Chainrings.
    Hate that the smallest 104mm is 32. Want that 29 back!
    "There is a big difference between kneeling down and bending over" -FZ
    mvi
    mvi is offline
    I put a road triple with one 39T in the outside position. Small Q.
    136 mm would not even clear a road bike. Forget MTB.
  1. Q-factor of Shimano XTR-970 crankset?
    By Danne in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-29-2007, 01:12 PM
  2. Q factor of XTR 970 crankset
    By westin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-15-2006, 10:36 AM
  3. Race Face Deus crankset q-factor
    By 20_bandh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-02-2006, 04:40 PM
  4. Replies: 8
    Last Post: 03-25-2005, 10:48 AM
  5. dragon bb/crankset q factor
    By jksu2000 in forum Jamis
    Last Post: 06-22-2004, 09:23 AM
