Results 1 to 3 of 3
    Apr 2013
    Changing stock Altus 7 speed RD to Deore on a Hardrock 2011
    I have a Specialized Hardrock 2011. Yesterday, while doing a bit of cross country the RD hanger snapped and I managed to wreck the 7-speed Altus RD. Should I just replace with another Altus or would it be possible to replace it with something a bit tougher like the Deore. I don't really want to replace any other parts and if it makes more sense to stick with the Altus in that case I don't have a problem with that, but I always like the idea of replacing broken components with better quality components where possible.
    I was looking at the Shimano Deore Shadow RD-M592-SGS, price doesn't seem too crazy. Would that be a straight swap or would I need to change other parts to get it to work? Any other suggestion, any pearls of wisdom gratefully received.
    Reputation: Aresab's Avatar
    The Deore will work fine, it's a 9 speed, but the pull ratio is the same across 7-9 speed, unlike 10-speed which is not compatible. I have a few of the RD-M592 derailleurs, they work real well. You may have to cut you housing a bit since the cable no longer uses a loop. Also, the Shimano removed the barrel adjuster on the derailleur, as long as you have one by the shifter, you should be all good to go.
    Apr 2013
    Thanks. I will check if the shifter has a cable adjustment.
  1. Upgrading Rusted MTB 2003 Shimano Altus 7-speed Freewheel Drive Train Parts
    By JakFrost in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-25-2012, 09:22 PM
  2. SLX or Deore for a Hardrock?
    By bravo4588 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-17-2012, 09:57 AM
  3. deore lx changing cage length?
    By ironmule in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-05-2012, 02:14 PM
  4. 2011 Hardrock or 2004 Hardrock Sport with upgrade?
    By tanglai in forum Bike and Frame discussion
    Last Post: 05-04-2011, 04:36 AM
  5. adjustment of stock suntour fork 2011 hardrock 29"
    By nephets0 in forum Specialized
    Last Post: 04-10-2011, 04:38 PM
