Results 1 to 2 of 2
    Norđwegr
    Reputation: Vegard's Avatar
    Changing from 32t to 36t on SRAM XX1, questions :)
    I'm putting a 36t on my bike as I found that the 32t was just too small for me and that I never used the largest cogs due to this.
    What will I need to do after I've put the 36t on?
    Got a new chain, but wondering if I need to readjust the derailleur screw and so forth?
    Thanks,
    Might not even need a new chain depending on how close you've got it sized now. I figure you'll only need an extra inch for the new chainring. Shouldn't need to adjust anything else - however, it never hurts to check your limit screws, bad things happen if your low limit is out.
  1. changing a cable on a fr xx sram
    By spencer lenz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-15-2015, 02:32 PM
  2. Changing gear questions
    By ch2s in forum Beginner's Corner
    Last Post: 03-10-2013, 08:28 PM
  3. Changing Sram 1250 chain rings
    By lastplace29er in forum 29er Components
    Last Post: 11-19-2012, 09:14 AM
  4. SRAM X9 10spd - changing thumb lever angle like X0?
    By -C- in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-15-2012, 04:42 AM
  5. Replies: 2
    Last Post: 10-07-2011, 06:09 PM
