Results 1 to 8 of 8
    Dec 2016
    Chainsuck problems bad.
    I think it's due to the front chain ring. Praxis cadet, the teeth are very square compared to other chain rings. Even narrow wide rings are more rounded than this. I assume that they do it to reduce chain drop and stuff but any time my chain gets any little bit of mud or silt in it, abnormal chain suck occurs. The guy I ride with suggests a different chain ring and hopefully that fixes it? Any other thoughts?
    meatier showers
    Dec 1999
    Yup, probably new chainring time. Best yet: get rid of all but one ring. Wide range one-by drivetrains rool. Adios chainsuck forever.
    =s
    disciplesofdirt.org
    Dec 2016
    Quote Originally Posted by Sparticus View Post
    =s
    Already is 1x. 94 bcd. Ouch. Anyone have any suggestions?
    Reputation: J.B. Weld's Avatar
    You could try a different chain, I've seen that solve chainsuck problems before. If not it seems like a different ring might be the only solution, that or avoid dirt.
    I brake for stinkbugs
    meatier showers
    Dec 1999
    Quote Originally Posted by Hbnel5on View Post
    Oh damn. Seriously? My hatred for chainsuck is why I went to 1x. Sorry & good luck.
    =s
    disciplesofdirt.org
    Give'er!
    Reputation: MCHB's Avatar
    Jun 2014
    As a last resort, you could try filing a chamfer on the leading and tailing edges of each tooth so that it clears the chain.
    Reputation: aliikane's Avatar
    Check to make sure your chain length is correct. A clutch rear derailleur may help keep the chain more taut.
    Dec 2016
    Quote Originally Posted by aliikane View Post
    Shimano xt m8000 is clutched
  1. XX1 chainsuck?
    By adictionbass in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-04-2014, 02:29 PM
  2. chainsuck on f29 C3
    By Notaskitrail in forum Cannondale
    Last Post: 05-31-2013, 12:47 AM
  3. MRP Chainsuck
    By hillbilly_hank in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-14-2013, 06:34 PM
  4. EMD chainsuck....HELP!
    By wheelgunz in forum Niner Bikes
    Last Post: 07-02-2011, 04:36 PM
  5. Went 2x9, now I have chainsuck.
    By bikerboyj17 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-18-2011, 05:43 AM
