Results 1 to 12 of 12
    Bunny Hoppin Gators
    Reputation: drivengsxr1000's Avatar
    chainring size on a 1x10
    is there some sorta magic formula to figure out what size chainring i should order for my 1x10 setup or is it basically trial and error. Im currently running a 32t ring but changed my mind on the color and ordered a new one 33t, i doubt im going to feel a difference in the 1 tooth bigger but i noticed there was much larger chain rings available like 36t, 38t, 40t
    Aug 2010
    No magic formula. It depends on your terrain and your riding style. Most folks just go with 32t. I ride hilly technical terrain and use a 30t chainring on my 1x9 to get a lower climbing gear, and it still gives me plenty of top end speed.
    Plays with tools
    Reputation: customfab's Avatar
    60 tooth or go home
    Bunny Hoppin Gators
    Quote Originally Posted by customfab View Post
    60 tooth or go home
    Win
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    32T is the sweet spot for the average rider - assuming 26". (29 or 30T on a 29'er). If you're above average and/or ride not so hilly terrain, go up to 34 or 36T.
    If not, 31 or 30.
    Old enough to know better. And old enough not to care. Best age to be.
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    Long time 1x9 riders here. My take, start with 32t and build up from there. Ive been riding a 38x11/34 9sp system on my 6" travel rig for years now. Im currently building up a 29er with 1x10 system and will probably start with 36t and 11/36 cassette, we"ll see how it goes. Good luck and remember dont give up, it will get easier, the human body is an amazing machine and insanely adaptable.
    #THELEGEND
    2016 RSD Mayor
    2017 Diamondback Haanjo Trail (Alu)
    Quote Originally Posted by jabrabu View Post
    cam you find a cheap 30T chain ring? most company only does 32T the smallest
    Aug 2010
    Quote Originally Posted by bapesta View Post
    For the standard 4-arm cranksets with the 104mm bcd, the smallest chainring you can fit is usually a 32t, unless you use the granny ring position. This is why you usually see 32t as the smallest available. For the older 5-arm compact cranks with the 94mm bcd you can go down to 29t, but it's harder to find chainrings that fit those.
    Some newer double cranks have a 120/80 bcd, and on those you could do a 28/bash or 30/bash, but singlespeed chainrings are not widely available for them. You could get chainrings made, though, from someone like Homebrewed Components (HBC).
    I use a spiderless chainring, which allows using any size you want. I use a 30t chainring from HBC, on a 29er.
    Attached Thumbnails Attached Thumbnails chainring size on a 1x10-niner%2520build%252021aug%2520001.jpg
    I'm talking abt the 4-arm 104 bcd chain ring...
    Reputation: AndyN's Avatar
    Home Brewed Components sells a 31 tooth for 104 BCD. $35.
    Reputation: Bailey44's Avatar
    Dec 2010
    Anderson Machine sells a nice 104 BCD 30t. It is spendy but to me it was worth it. You just have to file a tad off your spider arms to make it work. It took me about 10 minutes with a $4 file and your cranks can still be used for a 3x if you ever go back that direction.
    I'm running a 32t with a 12-36 on my 29er and the range is great coming from single speed only for the past 6 years. I am however, considering trying a 33t or 31t (I didn't realize you could get those for 104 BCD until reading this post) at some point because I seem to be missing a "sweet spot" ratio for me in between a couple of the cogs. I guess at some point I could figure out which ones they are and do a little math and whatnot.
  1. 1x10 Chainring Ideas/Questions?
    By Lenbo1982 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-07-2011, 10:11 AM
  2. Chainring for 1x10
    By frorider in forum 29er Bikes
    Last Post: 07-17-2011, 09:49 PM
  3. Can SS Chainring be used in 1x10 setup?
    By randyharris in forum Singlespeed
    Last Post: 01-27-2011, 06:36 AM
  4. single chainring for 1x10?
    By r1Gel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-04-2011, 04:23 AM
  5. can i use any front 34 tooth chainring to run 1x10?
    By Tintr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-04-2010, 05:38 PM
