Results 1 to 3 of 3
    Reputation: thebikedoctor33's Avatar
    chainring alignment?
    i recently took off my crankset to clean it, when doing this i tool all the bolts out and cleaned each ring individually. i put everything back together thinking everything was fine, but now the chain keeps coming off the ring, its not hitting the deraileur, it just comes off. it doesnt look bend, it looks like its not in line with the cassette and the rest of the chain. What did i do wrong???
    thanks
    andy
    Reputation: logbiter's Avatar
    keeps coming off which ring?
    did you make sure the rings are facing the right way?
    Also, the rings need to be in proper orientation, there is usually a notch/extra spline or arrow/triangle stamped on the chainring indicating that that should line up with the arm.
    did you install a new chain? new chain + worn rings = chainsuck, grinding & skipping
    Quote Originally Posted by thebikedoctor33
    thanks
    andy
    Live 2 Ride
    Reputation: Kona0197's Avatar
    When you put everything back together you didn't happen to install one or more of the chainrings backwards did you? Did you remember to put all washers back where they go to properly space the chainrings?
    My Bike: '15 Trek FX 7.2
    My Blog: http://http://kona0197.wordpress.com/
  1. MOTD: Make sure your chainring bolts are tight
    By dubjay in forum Singlespeed
    Last Post: 12-13-2004, 05:24 PM
  2. Guarding chainrings from rocks without replacing large chainring
    By lougrandview in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-11-2004, 10:46 AM
  3. Snapped a chainring bolt last night
    By Birdman in forum Singlespeed
    Last Post: 07-01-2004, 11:15 AM
  4. Is your front chainring Ovalized?
    By fc in forum Singlespeed
    Last Post: 06-11-2004, 01:43 PM
  5. XT chainring alignment
    By mike1964 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2004, 04:50 PM
