    Reputation: fire_strom's Avatar
    Chainline on SRAM/Truvativ Spiders?
    I want to run a 2x10 set up but I like both the lower gearing of the traditional 3x10 granny and the chainline of the middle ring. I have found the 2x10 rings are OK at both ends of the cassette but not as smooth as the middle ring on a 3x.
    Does anybody know if the spider/chainring sets sold as 22-36-gaurd are the same spacing as the 3x10's, ie. the 36t is in the normal middle ring spot?
    Thanks.
    I have a couple of brand new xo 3x10 spiders with 22-33-44 that I could run with the 44 removed but I would prefer to run a 22-36 or 24-36. If the 2x w/ guards are spaced right I would be looking for a trade or a sell/buy deal to get one.
    -G
    new name, old member
    Reputation: Bike Whisperer's Avatar
    The 22/36/Bash is just their standard 64/104 3 ring spider and uses the same chainline which is different than their 2x10 80/120 cranksets.
    Single and loving it (single speed bike that is)
    http://mtnbiker72.blogspot.com/
    http://www.ccfa.org/
    Perfect, thanks.
    -G
    I don't do PC
    Reputation: rroeder's Avatar
    Are the 22/36 and 24/38 chainring/spider combo's available without a bashguard? I have an XO 26/39 now and want lower gearing but don't need the basher cause I'm running a MRP 2x guide.
    I have also noticed that the chainline is not optimal, hard to get into the big/big combo, will the diff chainline of the smaller rings work with my MRP guide? The gap between the small ring and the guide is pretty tight as is.
    Thx
Hot Deals
Contests
Latest Mountain Bike Articles
