Results 1 to 8 of 8
Thread: Chain width
    Reputation: XC-TLC's Avatar
    Chain width
    I am curious if anyone knows the corresponding chain widths for different speed drive trains.
    According to Sheldon Browns site, 1/8 inch for 1-3 speeds and 3/32 for multiple speeds.
    I am pretty sure a 9 speed chain is skinnier than a 7 speed chain, but I cannot find specific measurements. Thanks for the help.
    I guess the reason for my question is that I have a 9 speed chain that I am wondering if it will work on a 7 speed drive train.
    Thank you.
    I'll kick you so had you'll starve to death bouncin'
    - My Grandpa
    Speak Softly and Carry a big stick
    ...idios...
    Reputation: SteveUK's Avatar
    You're correct that a 9 speed chain is narrower than a 7/8 speed. It means that you can use a 9 speed chain on 7/8 speed cassette, but the wider 7/8 speed chain will not work on a 9 speed cassette as the cassette sprockets are too close together.
    Diogenes
    Thank you.
    But still out of curiosity does anyone know where I might find actual measurements?
    - My Grandpa
    ...idios...
    Up to 8 speed is around 7.1mm or 7.2mm. 9 speed is up to 6.8mm and 10 speed up to 6.2mm. There are small differences between models and manufacturers.
    That makes sense, what does the 3/32 and 1/8 th actually measure? Is it the inside width of the skinnier half of the link?
    - My Grandpa
    ...idios...
    It's the internal width, between the link plates. As I understand it, 3/32" is typical for derailleur drivetrains, 1/8" for single-speed/BMX drivetrains.
    Thank you Steve UK you are awsome.
    So if I understand correctly:
    A seven speed and a nine speed have a 3/32in (2.38mm) inner diameter, but a nine speed would use thinner plates? than a 7 or 8 speed and thus have a narrower outside diameter?
    - My Grandpa
    ...idios...
    "A seven speed and a nine speed have a 3/32in (2.38mm) inner diameter, but a nine speed would use thinner plates? than a 7 or 8 speed and thus have a narrower outside diameter?"
    That's pretty much how I understand it, yes.
