Results 1 to 9 of 9
    boisebomber
    chain suck and slipppage
    had the bike shop install new cassette and chain....about $200.00
    now i have major slippage problem when peddling under heavy torque from standing start.
    also chain suck.
    what gives
    Pivoteer
    Reputation: tiSS'er's Avatar
    Not sure about the slipage, but the best item for chain suck is the Ronnie Ring. Best invention ever. It works.
    www.ronniering.com
    Employed by Pivot Cycles - www.pivotcycles.com
    Reputation: Wombat's Avatar
    I find that I need to change the chain rings at same time as the cassette and chain, otherwise it slips.
    Tim
    3 "fiddy" for short
    Reputation: be350ka's Avatar
    Dec 2004
    Degrease the chain if it hasnt already been. The tacky "lube" that comes on the chain from the factory, IMO, is like glue and creates more problems than not.
    Vaginatarian
    change the middle chain ring
    Cheezy Rider
    Reputation: Rufudufus's Avatar
    By slippage, do you mean that the rear derailler is shifting itself to the smaller cogs? Probably need to tighten the rear shift cable.
    200 bucks seems pretty steep, what did they install? And when you replace chain and cassette, you should probably get new rings too, unless they're pristine.
    boisebomber
    slippage
    from standing start in granny gear headed up sharp incline(aka.under hi torque) all hell busts lose....a klunk , a jerk and sometimes chain comes off.
    Quote Originally Posted by dan0
    Or, before changing, try to install it at 90 degree angle from the original position. No need to remove the crank or the chain ring, just remove the bolts, turn the chain ring 90 degree(either direction) and bolt it back.
    Sound like, you need chain rings, and to clean off the shipping lube from the chain and then reset up the shifting.
    As above
