Results 1 to 2 of 2
    Reputation: TwoPumpChump's Avatar
    Chain Sticks in Big-Big on 3x10 XTR Plus
    Anyone run into this before?...
    When accidentally shifting into the BIG - BIG combo & with the derailleur clutch on, chain wont drop down to a smaller cog upon shifting. Turn the clutch to the off position & problem goes away. I can drop to the middle ring to get things sorted out but in the heat of a race its a major pain.
    The only other time I ran into this was on another bike that wasn't running a long enough derailluer cage. Shouldn't be the case here.
    Here's the setup
    -xtr plus derailleur sgs (long cage)
    -xtr cassette 11-36
    -xtr crank 24-32-42
    -sram 1091r chain, sized according to sram recommendations
    Would adding another link fix the problem? Unfortunately this requires I buy a new chain.
    Or should I adjust the clutch internally? never done this before.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by TwoPumpChump View Post
    Here's the setup
    -xtr cassette 11-36
    -xtr crank 24-32-42
    Check the B-screw adjustment.
    Lengthen the chain.
    Can the clutch be adjusted? I do not know.
    mtbtires.com
  1. Chain tensioner on 3x9 or 3x10
    By HitmenOnlyInc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-21-2012, 09:04 PM
  2. Best chain for 3x10 XT?
    By Nygaard in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-10-2011, 02:21 PM
  3. Chain catcher for xo 3x10
    By jazzanova in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-14-2011, 07:57 PM
  4. Chain catcher for Tallboy with XO 3x10
    By jazzanova in forum Santa Cruz
    Last Post: 10-14-2011, 11:34 AM
  5. 3x10 Front Derailer Chain Rub Help
    By DTL in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-14-2011, 09:49 PM
