Results 1 to 6 of 6
    Chain Slipping issue....
    I should preface this question by saying that it only just occurred to me
    to write this at work and I did not check the wear on my cassette.
    Anyway, I was riding this weekend in extremely wet and muddy conditions,
    I had lubed the chain up pretty well before the ride.
    As I was climbing and I switched to a higher gear to do some standing the
    chain would slip out under pressure. If I shifted my weight further forward
    it would ease but that would take weight off my rear tire.
    Does this sound like it could be just the mud/wet? or is a new cassette in order?
    Drivetrain is all fairly new.
    Reputation: shiggy's Avatar
    Dec 1998
    Was there mud/debris packed in the cassette and/or the chain?
    8/9 speed setups are fairly sensitive to muck.
    mtbtires.com
    Your bike is incorrigible
    Reputation: Guyechka's Avatar
    another question
    By "slipping out" do you mean skipping over cogs or shifting down a gear? I've had trouble both ways. Skipping cogs is definitely a worn cassette. Ghost shifting can be a combination of worn cassette and something going on with the shifter.
    Quote Originally Posted by Guyechka
    It was skipping cogs. To answer Shiggy's it was not really packed with mud/
    Formerly DMR For Life
    Reputation: Full Mountain's Avatar
    Mar 2005
    couple things check for a stiff link although that seems unlikely due to the intermitent nature of the problem also i have had a bit of luck shortening the chain on my 2x9 setup not sure if this would work on 3x8/9 setup though due to the lenght of the chain
    DMR
    What if you did know...?
    Reputation: Tacoma4.0's Avatar
    Dec 2005
    Measure your chain. Put one pin on the 1" mark and go out to 11". If that pin is 1/16th" past the pin you have a worn out chain. If that is the case and the skipping just started you might get away with just a new chain. If it has gone on for a while you may need to get a new cassett. You also need to check/replace our chain rings as well
    Politics is the art of looking for trouble, finding it everywhere, diagnosing it incorrectly and applying the wrong remedies.
    Groucho Marx
    Under democracy one party always devotes its chief energies to trying to prove that the other party is unfit to rule - and both commonly succeed, and are right.
    H. L. Mencken (1880-1956)
    That government is best which governs least.
    Henry David Thoreau
    If this is the case the current Iraqi government is a raging success...)
