Results 1 to 7 of 7
Thread: chain slip
    I endorse self propulsion
    Reputation: biggsmoothe's Avatar
    chain slip
    hi guys, noob question...2 weeks ago i got an '05 Rockhopper comp and i'm having issues w/ the chain slipping when i put hard pressure on the pedal (due to steeper inclines). doesn't happen all the time, but enough to be annoying, and its not that its changing rings or gears, but its like it slips off of one link and catches the next. would this be caused by poor technique or is there a mechanical explanation? i've read about cable stretching, but would that happen this soon?
    Reputation: GearHead's Avatar
    Dec 2004
    Quote Originally Posted by biggsmoothe
    The cables will have stretched and the housing will have compressed throwing off the indexing of your drivetrain. This occurs on the first couple of rides until everything beds in.
    Also, a bent derailleur hanger would give you similar symptoms.
    There is no added value to my participation - in fact, just more confusion.
    Quote Originally Posted by GearHead
    so, assuming its not a bent derailleur, the slipping should resolve itself?
    Dec 2004
    Nope, it will either stay the way it is or only get worse.
    Reputation: OneEyeMan's Avatar
    Aug 2005
    Rotate the rear derailleur cable tension adjuster 1 click counter clockwise and ride.
    If you still get slipping, repeat till it stops.
    Lenny
    Dec 2004
    I wouldn't assume that it is not a bent derailleur hanger, I would check that too.
    Quote Originally Posted by Lenny
    Lenny
    i will try it....thanks!
