Results 1 to 7 of 7
    Chain rubbing on pulley.
    When I'm in the smallest chainring and cog, the rear derailleur pulley rubs on the cog and sounds terrible. How can I remedy this. Someone told me just not to use that gear combination..? Also, I just got his bike and I just finished tuning the rear der. since it came all messed up and it's a little noisy. It shifts fine, but it's noisy. I've got powerglide cassette and x7 rear der. The bike is a Woodstock 505.
    -Avinash
    Hazzah!
    there should be an adjustment screw that sets the gap between the upper pullly and the smallest cog(at least there is one on my x9).....you might want to take some links out of that chain also....
    Is the screw your talking about called the B-Screw? With this turned fully in, it doesn't help. According to SRAM's directions, you should give it extra 2 links while on the largest chainring and largest cog. I checked this and it seems to be fine.
    You think I should take 1 link off?
    -Avinash
    neutiquam erro
    Reputation: Chris130's Avatar
    Mar 2005
    Don't use that friggin' gear combination! It's called "cross-chaining" and is a very evil thing to do to your drivetrain. Same thing with the "big-big" combo. Your RD is all shrunken up and your chain (assuming it was sized properly [not using RD as kattywhumpus says above]) looks loose in that pic because you are in small-small and your poor chain isn't wrapped around very many teeth (so it's just hanging there because there's hardly any tension in the drivetrain overall).
    Do not cross-chain - nothing good comes of it!
    Cheers, Chris
    Now is the time on Sprockets when we hammer.
    '05 Blur Classic (1x9) || '06 SIR9 (SS) || '06 Brompton P6L
    Hazzah!
    Quote Originally Posted by avinash
    -Avinash
    ya its the B screw...if your turning that and its not helping something else is your problem....when you checked your chain length you didn't go through the derailure(?) correct,,,?,
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    I seriously doubt the B-tension screw will do anything to help that.
    1. Don't use that gear combo
    2. If you insist on using that gear combo, try removing a few links from your chain.
    Smile
    Thank you guys for all your help. I've decided I'm not going to remove any links and just avoid that combo. I did some research and it looks like the best method is to just avoid that gear combination.
    The B-screw did not change anything and it also states in multiple sources that it should not be used for that purpose
    Thanks everyone.
    -Avinash
