Results 1 to 2 of 2
    Reputation: newMTBer's Avatar
    Chain rubbing front derailer
    I know I shouldn't have my chain angles like this for real use, but I cleaned my chain, cassette, and front cogs last night (had to take rear wheel off). So when I got it cleaned and put the wheel back on I ran through all of the gears jsut to make sure I had every thing back together right. When I had the chain on the second cog in the front and the 8th in the back the chain just barel rubs against the front derailer so that I hear a sort of clicking sound. Is this something that I caused by not putting the rear wheel on correctly, or is this nothing to worry about because I shouldn't have my chain angled like that anyway? I'm not sure if it was like that before because I never really use that gear combination. Thanks.
    Harky
    You should be able to run thru the full 8 or 9 rear gears without having any drag on the front d/r set to middle ring. There should be a adjustment on the shifter housing where the cable attaches that allows you to center the cage for no rubs. Try that. If you can't center the cage with the adjuster, a cable adjustment at the dr will be necessary. I suggest having your LBS do this for you as it's kinda tricky.
