    I like bikes
    Reputation: beekeeper357's Avatar
    chain retention on 1x9?
    I am preparing to build up a new ride and want to make it a 1x9. With no front derailleur and only the one front chainring. Do you think a chain retention devise will be necessary or will the tension from the rear derailleur keep the chain from coming off the front ring? More than likely I'll have a 32 tooth chainring with a bashguard/rockring. I'm still debating whether it will be full-suspension or hardtail, but more than like likely it'll be an F.S. rig. Thanks
    Perpetually single track
    Reputation: ibmkidIII's Avatar
    I think you could also get a ring up front that has taller teeth (e.g. not designed to be shifted off of, like for a SS) and that'd help you out. I bet you'd still drop your chain every now and then though still without a chain guide...just depends how much you want to deal with it.
    On MTBR hiatus :(
    Agreed, with a Spot or Salsa non-profiled ring, you'll have the best bet against random chain drops.
    A short cage derailleur provides more chain tension than a longer one. With a 1x9, running a GS or even an SS cage length is not a problem.
    However, since you're planning to run a bash ring, you're halfway there. Why not just add a Jump Stop or Third Eye and you'll be all set.
    Quote Originally Posted by beekeeper357
    I was thinking of the same setup.On my DMR Switchback the chain defintely de-rails
    on my 2 largest rear cogs.I'm going to get an E13 chain guide to fix.
  1. Good info on bike locks.
    By 2melow in forum General Discussion
    Last Post: 02-06-2005, 01:02 AM
  2. Paging pete (chain retention device question)
    By fireboy in forum Passion
    Last Post: 06-19-2004, 10:26 AM
  3. Triple chainring chain retention device?
    By Freerider in forum Downhill - Freeride
    Last Post: 04-29-2004, 07:49 AM
  4. Triple chainring chain retention device?
    By Freerider in forum General Discussion
    Last Post: 04-28-2004, 11:41 AM
  5. Triple chainring chain retention device?
    By Freerider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2004, 10:46 AM
