Results 1 to 3 of 3
    Chain re fitment question.
    Hi
    Ok so you know when you put on a new chain on an old cassette you sometime get the chain skip when put under tension while pedaling.
    Well...
    I recently had my chain off to carry out some work on the bike. Now i have it back together using the same cassette and chain as there both only a couple of hundred miles old. I get a one tooth skip under tension. Normally in 8th which i suspect is the most worn gear.
    Is it possible to put the chain on upside down? Creating a new chain old cassette effect? Could flipping the chain solve the problem?
    If you think about it putting the chain on upside down would mean the chain is leading with a different side of the link.
    Obviously i could just try it but wanted to ask if anyone else had encountered this before.
    Joel
    Follow me on Twitter @OnOneCarbon456
    Hi I'am an On-One Carbon 456 mountain bike, follow me to find out what i get up to...
    Are you sure the powerlink you used is the correct one and that it's installed properly?
    I suspected it might be the power link. Again the same link as before i took the chain off. I wondered if it was the power link or one link that was giving me a random or one tooth skip.
  1. Need new chain? (not a chain wear question)
    By aBicycle in forum General Discussion
    Last Post: 12-02-2012, 10:35 AM
  2. shock fitment question...
    By the_Alaskan in forum Shocks and Suspension
    Last Post: 09-26-2012, 08:40 PM
  3. Question about fitment on 2010 Norco Bigooft
    By TheRed06 in forum Brake Time
    Last Post: 08-27-2012, 02:04 PM
  4. Building first SS - chain ring / chain question
    By BigwheelsRbest in forum Singlespeed
    Last Post: 03-13-2012, 09:45 PM
  5. Replies: 3
    Last Post: 03-04-2012, 08:40 PM
