Results 1 to 3 of 3
Thread: Chain Length
    Apr 2005
    Cool-blue Rhythm Chain Length
    I just replaced my rear derailer. Deore LX M570 with a Deore LX M580. LBS said it was the same derailer, just a longer cage. Also am replacing the chain. How many more links should I add to compensate for the extra cage length? Is there a website that has pictures of what the derailer should look like on a certain gear/chainring combination. Or is there some rule of thumb?
    Thanks in advance.
    Reputation: logbiter's Avatar
    http://www.parktool.com/repair_help/...ex.shtml#chain
    there ya go
    Quote Originally Posted by KJN185
    Thanks in advance.
    Do It Yourself
    Reputation: Homebrew's Avatar
    A longer cage derailleur shouldn't require any additional chain length. It just adds more chain wrap capacity so you can maintian tension over a larger gear range. So if your chain was correctly sized before, the new one should be the same. It's best to just do the big ring, big cog, no derailleur, add 1" method to be sure.
    Long Live Long Rides
  1. Determining the chain length at borderline?
    By PiroChu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-15-2004, 08:28 PM
  2. Epic chain length
    By Jackie in forum Specialized
    Last Post: 11-11-2004, 04:08 PM
  3. Fiddling with chain length
    By SpinWheelz in forum Singlespeed
    Last Post: 11-01-2004, 03:58 PM
  4. Quick and Easy Formula for chain length?
    By gspot in forum Singlespeed
    Last Post: 11-01-2004, 08:35 AM
  5. Paging Kman: Fuel 100 chain length??
    By CODMAN in forum Weight Weenies
    Last Post: 05-10-2004, 01:07 PM
