Results 1 to 7 of 7
    Chain jumping from small chainring to middle chainring
    Anyone ever have the chain jump from small chainring to the
    Middle chainring under load? This is happening to me on my last ride and I can't figure out why. The cassette is holding fine it's just the front. Could a bent rear derrailleur Cause this? I have a Santa Cruz tallboy and the chain is a year old. I just lubed it and I'm stumped as to why this is happening. I'm hoping someone else out there has had this issue. When climbing and under load on the non drive side crank the chain goes up to the next chainring.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by menusk View Post
    Bet it only happens when on the middle to smaller cogs of the cassette.
    Don't use them with the inner ring.
    The chain angle has it too close to the middle ring and the chain is picked up by the shift pin/ramps.
    mtbtires.com
    Yup I think you're right. I have 24t granny ring that I can replace the current 26t with. To see if i can get the chain away from the shift rings.
    You'll still need to modify your gear selection habits. You might get less pickup on the first gear that happens with, but nothing more.
    Dec 1998
    No need. Just do not use those gear combos. The ratios are duplicated on the middle ring. Only use the 2-3 largest cogs with the inner chainring.
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    This is the best piece of advice. If you absolutely must, though, you can grind the shift pins off of the middle ring. Your [intentional] shifting, however, will suffer as a result.
    Plays with tools
    Reputation: customfab's Avatar
    There is zero reason to run a small/small combo or anything close to it. Cross chain the other direction all you want.
  1. Anyone else running a 28 tooth middle chainring ?
    By phoenixbikes in forum 27.5 - 650b
    Last Post: 09-24-2012, 01:02 PM
  2. Chain jumping gears..caused by smaller chainring?
    By Crash Dummy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-19-2012, 11:32 AM
  3. Cross Chaining in Middle Chainring...
    By Ace5high in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-23-2012, 06:36 AM
  4. Front der chain rub in small chainring
    By velocanman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-12-2011, 06:29 PM
  5. PLEASE HELP! Tracer vp chain rub on small chainring
    By stepping-razor in forum Intense
    Last Post: 06-29-2011, 02:34 AM
