Thread: Chain Install
    Apr 2013
    Chain Install
    Heyguys,
    I am upgrading from 8 Spd to 9Spd. I have the 9spd chain but do i make it the same length as the 8spd or should it be a link longer or what?
    Kick Start My Heart
    Reputation: davez26's Avatar
    Dec 2004
    Re: Chain Install
    Difference btwn 8 and 9 is width btwn sprockets. If cassette is same small/large sprockets, length is the same.
    Sent from my DROID RAZR using Tapatalk 2
    Reputation: Nater's Avatar
    Number of cogs in the cassette in no way affects chain length.
    If your big cog and your big chainring are the same tooth counts on your new 9 speed stuff as they were on your old 8 speed stuff, then chain length is exactly the same (assuming it was correct in the first place). If you've changed your gearing ratios along with the number of cogs in the cassette, you may need a new chain length.
    Apr 2013
    Ok thanks. I did upgrade the cassette i will have to check the amount of teeth etc then.
  1. Will I have to adjust FD if I install smaller chain ring?
    By jnoss97 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-26-2013, 08:40 PM
  2. Build question (chain install)
    By Boatracer in forum Fat Bikes
    Last Post: 10-10-2012, 07:41 PM
  3. Chain Install
    By sasquatch35 in forum Tooltime
    Last Post: 08-01-2012, 06:42 PM
  4. ISCG-05 Chain Guide Adaptor - install questions
    By Raine in forum Pivot Cycles
    Last Post: 03-17-2012, 03:35 AM
  5. Chain whip necessary for Install / removing a Cassette?
    By ILMTB in forum Beginner's Corner
    Last Post: 05-20-2011, 01:00 PM
