Results 1 to 2 of 2
    Chain guides & bottom brackets? x- post
    I purchased an MRP LRP chain guide. I have an LX octalink crankset and an XT BB. The XT BB has 10mm of threads on the drive side cup, the MRP bracket is 3mm thick, the BB enters the frame about 2.5 mm before thread contact - so if you do the math I have less than 5mm of threads in the frame ( 3 whole turns of the BB). Are chain guides and Shimano a bad mix? I went into the LBS where they suggested an XT E type BB - well it has only 11mm of threads. Pictures of DH ISIS BB's appear to have more threads. What to do? Thanx
    Reputation: skywaybuzz's Avatar
    Keen I use the Evil chaiguide with the same cranks+BB. The bracket looks about 3mm thick so I feel you'll be OK. There aren't any threads on the BB where the bracket will sit anyway.
  1. Chain guides & bottom brackets?
    By keen in forum Downhill - Freeride
    Last Post: 08-28-2004, 11:05 PM
  2. @#$%^&* Shimano bottom bracket mounted derailler
    By old_dude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2004, 10:04 AM
  3. Do chain guides help chain jump
    By stinkydropoff in forum Downhill - Freeride
    Last Post: 05-29-2004, 10:14 AM
  4. Token ISIS bottom brackets [o]
    By positron in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-24-2004, 04:04 AM
  5. Weight of 04 shimano bottom brackets?
    By mtb_biker in forum Weight Weenies
    Last Post: 03-24-2004, 04:13 PM
