Results 1 to 6 of 6
    Reputation: Alexgonzalezmi's Avatar
    Chain drop only in low gear
    I've been having a weird issue where if I put the bike in the lowest gear (highest cog in the rear) the chain has a hard time staying on the big ring in the front. There is no front derailleur rub either. I can replicate it on the stand by holding the rear brake and pushing on the pedals. If I push hard enough I can actually make the crank slip. It's a KMC X10SL chain, XX crank, XO cassette. Are the KMC chains directional? Do I have it on backwards? It's not an old chain, but the frame is new. I pulled all my components off my old bike and put them on here. It's a Niner Air 9 RDO.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Alexgonzalezmi View Post
    You should not use the big-big combo. Poor chainline, high wear, low efficiency, and drops off the ring easily
    mtbtires.com
    Apparently the chainring is smoked. I put a different chainring on and it works fine. The only problem is that its a 42t XX on a Air 9 RDO which isn't recommended.
    Dec 1998
    The poor chainline is still a factor and the chain is more likely to drop when using the big-big combo.
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    Never had a chaindrop off the big big combo.....and yes I ride it frequently enough....to make it through steep gullies...
    This combo should work fine on most bikes....mine is 44/22 and 34/11....
    Yes it increases wear nevertheless this is often avaluable riding combo.
    The chain is held tight because the RD is fully stretched in this gear.
    I ended up stealing the 39 off my wife's bike. Everything works fine now. The teeth on my old ring are just fried.
    Sent from my Xoom using Tapatalk 2
