Results 1 to 11 of 11
    Jun 2012
    Chain drop drop off and misalignment a norm?
    Hi, I would like to know if it is a norm to have chain misalignment when u put the front gear to the biggest cog and the rear gear to the biggest cog and the sounds gets louder.And when u reverse pedal, due to the misalignment, your rear gear will drop to the smaller cog when u are at that particular configuration.help!!
    Sent from my GT-N7000 using Tapatalk
    29er
    yes, that is normal, it is called the cross gear
    avoid big big, and also avoid little little
    Jun 2012
    It is normal too for the chain to drop off?
    Reputation: Shalom's Avatar
    Nov 2008
    Depends on the set up and the condition of the drive train. But it can happen.
    Nov 2008
    Picture of cross chaining
    Example of acceptable gearing combinations for a typical 9 speed
    Jun 2012
    How do i read the 2nd diagram?eventhough i placed my gearing at front big and rear 2nd from the biggest,it will drop of if i reverse pedal. And if i pedal forward,the sound is rough.
    29er
    may just need adjustment
    Enthusiast
    Reputation: JonathanGennick's Avatar
    Quote Originally Posted by boardrider02 View Post
    It's common for the noise to increase as the chain becomes more and more misaligned. It's also considered poor form to ride in the big/big combination. Sometimes in the heat of the moment I'll end up in poor gear combination, and I take the noise as my hint to shift the chain into better alignment.
    However, your chain shouldn't drop when you back-pedal. At least, it shouldn't drop on the stand with everything clean and well-lubed , and well-adjusted.
    Jun 2012
    I readjusted as perfect as possible...but it cant.as i look from the front,there is no way it wont drop as the alignment is obvious.hmm.scratch heads...
    Reputation: shiggy's Avatar
    Dec 1998
    It is entirely normal for the chain to move down the cassette if you back pedal in the big/big combo ("drop" usually refers to the chain coming off the chainrings).
    Still, you should have the derailleur hanger alignment checked.
    mtbtires.com
    Nov 2008
    The second picture is more for derailleur cage lengths, but will do to illustrate something roughly here. The green boxes are the acceptable gearing combinations - roughly. So from each chain ring, you cannot reach all of the cassette without cross chaining. But as I said, it is not entirely accurate. I could not find the picture I was wanting.
    If it is sounding rough and dropping while back pedalling, it sounds like setup to me. Possible cable tension is too much/not enough, leaving the RD in between gears.
