Results 1 to 27 of 27
    Thread Killer
    Reputation: bucksaw87's Avatar
    Chain...completely seized
    As the title says, my chain is completely rusted solid...quite a few of the links won't move at all, so the chain is mostly stuck in a hoop shape. I've got it soaking in a tub of coke, just to see if it'll free itself and be somewhat usable again, but is there anything else I can do? Does PB-Blaster and Slick 50 work well on freeing up stuck chains? Or, am I basically stuck with having to buy a brand new chain?
    I ride a 26'er with tubes and rim brakes.
    Yeah, I'm basically living in the stone age.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Do yourself a favor and buy a new chain .
    Thread Killer
    Quote Originally Posted by AZ.MTNS
    meh, fair enough
    you're not Dremer03 are you?
    Former Bike Wrench
    Chains are $20 or less for reliable replacements...get a new chain
    Reputation: tm240z's Avatar
    Depending on wear, a new chain might not mesh with the old ring/cogs, correct?
    Former Bike Wrench
    Quote Originally Posted by tm240z
    Correct...given the limited information given by the OP, one can only give an answer to what should be done with the rusty chain.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    THIS will help an old rusty chain.
    Honestly... ahh I give up
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by bucksaw87
    There is only one solution: replace it.
    mtbtires.com
    Thread Killer
    Quote Originally Posted by highdelll
    Sheldon Brown to the rescue again!
    AZ
    AZ is offline
    meh, fair enough
    No , the farthest thing from it .
    Former Bike Wrench
    Nice
    AZ
    AZ is offline
    Works fine till you wind up with extra parts .
    ~Disc~Golf~
    SS then!!
    Wow! That is time intensive.
    You would need to have a very special relationship with that chain,
    or at least you would when you were done.
    ballbuster
    Reputation: pimpbot's Avatar
    ah.....
    I miss Sheldon. RIP, buddy!
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    sell it on ebay as "art" ... use profits to buy a new chain
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Thread Killer
    Quote Originally Posted by Zoke2
    i could hack up a chainring and make some bottle openers with the chain as a handle!
    Reputation: clutch_08's Avatar
    spray it with wd40 it worked for my chain and move every link up and down
    Ride Responsibly
    Reputation: LWright's Avatar
    If it is that rusted, getting it moving again is possible, but what you need to worry about is the chain being weaker now, and breaking when you least expect it.
    Avoid cancer, buy a new chain.
    Old man on a bike
    When you get the new chain get some lube, too....and use it!
    suum quique
    Vaginatarian
    I would think that having a chain that rusted means other issues also, I would check every bearing on the bike
    Vaginatarian
    Quote Originally Posted by dan0
    I would think that having a chain that rusted means other issues also, Rode hard , put away wet
    Thread Killer
    ugh, i know.
    i love having a bike rack on the back of the car...especially in the winter with wet, salty roads *facepalm*
    Feb 2010
    Oh snap...
    Quote Originally Posted by LWright
    Its true, I might be new to getting into this but my first real ride I went on the guy I went with had a fairly rusty but still usable chain, snapped in under a mile of a good up hill.
    Reputation: hootsmon's Avatar
    Thanks guys, reading this thread just made my day!
    Brisbane, AU
    Nov 2008
    Coke? as in "things go better with Coke"? How's that going to help. If you want to try and save this chain, soak it in a bit of alcohol to wash out the Coke, let it dry and soak in a 50/50 blend of motor oil and solvent (mineral spirit, or naphtha, for 24 hours.
    After soaking it flex it over a water pipe or similar round stationary object, and work it back and forth under light tension, shoe shine style. If most of the links free up, you can break the last few free by using 2 adjustable wrenches and flexing till they're free.
    If you can't get most of it to flex over the pipe, it's scrap metal.
    Now soak it in oil, wipe off the excess & install it. It might skip a bit as a few stiff links work loose, but a few spins around the block should get it working nicely. Obviously it won't be good as new, and depending on the depth of the rust it's strength will be reduced, but it'll be fine for a commuter or utility bike, ridden on flat ground.
    BTW, rusty chains like this one are a classic problem for "island bikes" at summer homes in places like the barrier islands of the east coast. One nice feature of beach cruisers is that since there's no derailleur, rusty chains can be broken free simply by soaking in oil for a day, and standing on the pedals.
    fb
    www.chain-L.com
    The key to solving any problem is to understand and address the underlying cause.
    Thread Killer
    Quote Originally Posted by FBinNY
    yes, that kind of coke...it's worked well with many other rusted-to-hell steel bits i've encountered, so i figured might as well give it a shot. something about the phosphoric acid in the coke reacts with, and neutralizes the rust and oxidation and cleans the area pretty nicely. i've cleaned up many a rusted chrome part on old bikes, as well as a meat cleaver dating from the 1800's...although, the phosphoric acid "parkerized" the cleaver and left a pretty cool grey finish on it.
    in any event, and like others have said, my best option at this juncture is gonna be buying a new one...although i seemed to have missed the part about "cheap" chains. the cheapest i've encountered was $23, with the average price locally being in the $30 range.
