Results 1 to 11 of 11
    Reputation: jekramerjr51's Avatar
    Cassettes and Chain Length
    I'm thinking of going to a 12-36 from a 11-32 rear cassette. I know this may sound a little redundant,but will I need a longer chain? If so,by how much? Thanks for any and all comments.
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    It depends... You're adding one tooth. Adding one link equals two teeth. Also depends how much slack you have now.
    I know I'm lousy at math and I know your going to get into gear ratio's but,how does going from a 11-32 to a 12-36 only add one tooth?
    Mountain Man Dan
    Well, I Googled the question............ Google is your friend.
    The difference is 4 teeth. I wouldn't worry about it, as long as you don't use any stupid gear combos you'll be fine.
    Nah, no crazy combo's,just changing cassette's and probably a new chain.Will the derailleurs need to be readjusted for the new 12-36?
    Mountain Man Dan
    You could always do the big ring, big cog combo to get the correct chain length.
    wyrd bi ful rd
    Reputation: chinaman's Avatar
    Keep your current chain, unless you will use the large chainring with the largest cog of your new cassette. I think the next size down will be a 32T ... so you can still effectively use that cog with the largest chainring, but will you???
    Actually on that note, I have never gone to the 3rd largest cog with the largest chainring in front before ... and I used the chain length measurement below ... with the 2 extra links ...
    Just tried largest chainring & cog and the derailleur looks quite stretched to me ... not something that I would use as I am sure I can get approximately that ratio elsewhere ...
    Derailleur adjustment ... not sure about SRAM, but with shimano ...
    Chain length if you decide to change is ...
    www.derbyrims.com
    Reputation: derby's Avatar
    ... and measure a full suspension for chain length at bottom out (shock disconnected or completely deflated). Because almost all suspension bikes "grow" in distance between the rings and cogs while compressing deeper into travel.
    Dirty nerotic bike whore
    Reputation: Dirty Bastard's Avatar
    Keep this in mind, any time you repace a cassete or front chain rings its always with a bran spankin new chain. This does not apply to cassette and chain rings when replacing the chain but well you get the idea.
    ... and if we just ...
    Thank you to all for your suggestions. I replaced cassette and chain without a hitch! And the bigger gear works great when climbing!
  1. Old components on new frame .2" shorter chain stay - chain length reduction?
    By DPDISXR4Ti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2011, 03:32 PM
  2. kona caldera needs new cassettes and chain.. help
    By canadiangator in forum Kona
    Last Post: 04-12-2009, 08:16 AM
  3. Sram Cassettes and chain
    By Boyonabyke in forum Where are the Best Deals?
    Last Post: 11-22-2007, 08:28 AM
  4. One chain two cassettes or one chain one cassette?
    By MillerSHO in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-24-2007, 09:10 AM
  5. calculating chain length w/cage length
    By Slobberdoggy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-05-2006, 07:43 AM
