Results 1 to 6 of 6
    meow meow
    Reputation: b-kul's Avatar
    cassette question
    i just got a charger pro wheel set with an alloy free hub. my cassette is made up of individual steel cogs. i ride 1x9 but don't put down tons of power and am around 150 pounds. should i upgrade to a cassette with a carrier or do you think i will be okay?
    Binned
    Nov 2008
    It would seem that running 1X9 would require some hard pushing at times which could ultimately dig into the carrier. I'd go with a cassette upgrade if I were you.
    Plays with tools
    Reputation: customfab's Avatar
    It's not like your current cassette won't work. Sure it will dig in a little bit, but 2 minutes with a file will cure any damage a 150# amature can create. Upgrade your cassette when it's worn out, that's my recommendation anyway.
    meow meow
    Quote Originally Posted by customfab View Post
    alright, thanks for the reply. that was what i was figuring.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    Quote Originally Posted by b-kul View Post
    ya, I'd probably just get a new cassette... What Customfab is is 100% correct, but one thing I've found is after it digs in it makes it really hard sometime to remove. The last one I did (hope Hub, but same idea) I had to actually pull the freehub off and jiggle it around then finally tap with a bearing remover and hammer to get the cassette off it.
    RIght now there are a few places selling the 990 cassette for under 60 bucks... just saying
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    meow meow
    kinda the realization i had, i spent all this money on a nice wheel set, why cheap out on the cassette and potentially mess it up? i have a xt on order.
  1. Cassette question?
    By bassn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2012, 07:41 AM
  2. Cassette 34T - 36T Question.
    By Cynical19 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-30-2011, 07:20 PM
  3. Cassette Question...
    Last Post: 11-30-2011, 06:34 PM
  4. Cassette question
    By Gus68 in forum Beginner's Corner
    Last Post: 09-25-2011, 01:28 PM
  5. Cassette Question
    By jdmaum1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-04-2011, 09:26 AM
