Results 1 to 6 of 6
Thread: Cassette Issue
    Cassette Issue
    Sorry - if this is the wrong forum/subforum but I have this problem where my derailleur (SRAM X9) will not go down to the smallest cog even though I adjusted the screw to it's fullest. Any ideas. First time issue for me and I've changed out at least 4 derailleurs and only God knows how many cassettes. Tx in advance!!!
    Reputation: shiggy's Avatar
    Dec 1998
    Cassette Issue
    Quote Originally Posted by zenmster View Post
    Moved to drivetrain...
    Reset the cable.
    mtbtires.com
    Just to be sure - you mean loosen the rear derailleur cable and allow the derailluer to settle in at the lowest cog?
    Tried that...maybe you mean something else?
    Quote Originally Posted by shiggy View Post
    Reset the cable.
    Dec 1998
    Cassette Issue
    Add a washer to move the RD outboard a bit.
    mtbtires.com
    Reputation: GTscoob's Avatar
    This. SRAM derailleurs dont seem to agree with steel frames and I've always had to put a 10mm washer up underneath the hanger bolt in order to properly adjust the high limit screw.
    Dec 1998
    Cassette Issue
    Quote Originally Posted by GTscoob View Post
    I think the return spring runs out of travel.
    mtbtires.com
  1. Shimano cassette a bit loose on rear cassette hub
    By anymore in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-04-2013, 03:50 AM
  2. Strange rear cassette issue.
    By DYI01 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2013, 04:47 PM
  3. My Saddle Issue May Fix Your Back Issue
    By Fleas in forum General Discussion
    Last Post: 07-18-2012, 06:17 AM
  4. Replies: 16
    Last Post: 04-04-2012, 05:39 PM
