    Cassette compatibility
    Hey guys,
    I building a second set of wheels for my 29er and I have a general question about Cassette interchanging.
    My current wheels have the following 9 spd rear cassette:
    Shimano CS HG-50 -9 / 11-32 T
    The new wheels I bought came with the following 9spd cassette:
    Shimano HG-61, 12-36
    My original thought was that I can use either cassette without having to adjust anything simply because they are both 9spd. I am starting to think otherwise since the teeth are different.
    My question, When swapping between these 2 gears, would you expect to have to adjust the derailers or anything else?
    Thanks in advance,
    Ian
    Reputation: DavidR1's Avatar
    The shifting should be fine, you may have to adjust the "B" screw though.
    Assuming of course that the cage on your rear derailleur is long enough to accomodate the 36t, and that your chain is long enough.
    CyclingCentralVa.org
    Thanks for the response. So as long as it fits under the chain and shifts ok, I shouldn't have anything to worry about? (sorry such basic questions)
    Ian
    Quote Originally Posted by xianmacx View Post
    Ian
    Are you familiar with the "B" screw adjustment? If not, you may be better served to take it to a shop. This tutorial may serve you well also: Park Tool Co. ParkTool Blog Rear Derailler Adjustments (derailleur)
  1. 10 speed cassette hub compatibility
    By rynogee in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-30-2011, 04:25 AM
  2. Need help with Cassette and compatibility
    By enyceckk in forum Bike and Frame discussion
    Last Post: 07-17-2010, 07:55 AM
  3. Cassette compatibility
    By CarlTroy in forum Wheels and Tires
    Last Post: 03-20-2010, 09:03 AM
  4. cassette & hub compatibility?
    By mb-3 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-10-2009, 09:10 AM
  5. cassette / chain compatibility
    By wrecked in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-29-2007, 10:00 PM
