Results 1 to 14 of 14
    MK_
    MK_ is online now
    carpe maņana
    Reputation: MK_'s Avatar
    New question here. Cassette carrier dimensions
    Would anyone be kind enough to enlighten me with dimensions of the cassette carrier (shimano), the width and the od of the splines and between the splines? Thanks!
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    Mar 2005
    Huh?
    Way Too much work.
    I think all you need to know is the following two facts:
    Shimano = slop & a prematurely worn out freehub body.
    SRAM = perfection & a long lasting freehub body.
    mechmann_mtb
    Guest
    i disagree with the previous post in that a properly spaced and tightened cassete is not going to cause any damage.
    HOWEVER...
    the new SRAM cassette with the red spider is pretty trick looking.
    Mar 2005
    Disagree all you want...then perform the following test:
    Take a new Shimano compatible cassette hub off the shelf.
    Grab a brand new Shimano XT or XTR cassette (just the carrier part with the cogs attached).Slide it down over the hubs cassette body. Now grip it with your hand & move it in a parallel orbital rotation. Notice the play? Ridiculous huh?
    Now do the same test with an SRAM cassette. Slide it down over that Shimano comapatible cassette body & try to give it the same parallel orbital rotation. Where did the play go?
    Choose & spend your hard earned dollars wisely.
    MK_
    MK_ is online now
    carpe maņana
    I don't care to know your cassette preferences. I would like to learn the dimensions of the hub so that I can machine myself some spacers for a single speed conversion.
    _MK
    Old man on a bike
    So you want the measurements of a Shimano freehub body, or a Shimano cassette carrier?
    suum quique
    MK_
    MK_ is online now
    carpe maņana
    Quote Originally Posted by Bikinfoolferlife
    The piece of the hub onto which you slide the cassette, King calls it drive shell, but in their terms it includes the engagement teeth and a bearing. I assumed it is called a cassette carrier.
    _MK
    meh....
    Reputation: Monte's Avatar
    Quote Originally Posted by MK_
    _MK
    Here's the ID of a spacer from a King SS hub, 34.75mm, or 1.368"
    Monte
    MK_
    MK_ is online now
    carpe maņana
    Quote Originally Posted by Monte
    Monte
    Thanks.
    _MK
    meh....
    Welcome....
    Thanks.
    _MK
    Monte
    Bringing this thread back from the dead because it was the only one I found to deal with this issue. I found some tubing from which I could cut spacers, so that's all gravy, BUT...the OP's question is more detailed, and I too would like the answer.
    Where can I find engineering drawings of a shimano-compatible freehub body? If for example, I wanted to have cogs made, or spacers that fit the splines.
    Vaginatarian
    Quote Originally Posted by Elzippo
    perfection?
    my last sram990 had a burr on the third cog so it wouldnt even go on the freehub, after filing it finally went on , then 4 rides later the 2 largest cogs were bent so badly that the chain wouldnt stay on them. they warrantied it but I wouldnt say perfection
    no play on my I9 hubs, although the Sram aluminum spider is easier on the freehub body than a steel carrier
    Vaginatarian
    why not go to a lbs and pick up a old one ?
    mostly because I assume there's a reference diagram, "standard" as this is...
    and secondly, because I don't want to be plagued by cumulative error, of the original machining, of damages/distortions from use, my measurements, and then the machining I have done based on said measurements.
    It would be better to have an original spec, ideally from Shimano (who don't reply to e-mails)
