Results 1 to 5 of 5
    A Mountainside=My Therapy
    Reputation: ColoMtb20's Avatar
    Cassete Compatibility
    I did a quick skim through the forum and didn't find an answer to my question, so here it is. Will a SRAM 7 speed PG-730 Cassette fit on a Shimano Deore M530 rear hub? I just find it hard to believe that they make a 7 speed cassette and don't sell a new hub that it works on. Just hoping that someone can shed some light on this situation. Thanks
    Mar 2005
    They may make a 7 speed cassette for whatever application (my guess is they exist for some low end commuter/hybird application), but 7 speed has not been current for something like 15 years. 7 speed cassette spacing requires a 7 speed shifter, and is narrower than any current freehub by about 5mm. You could use spacers to take up the excess space....
    So does that mean a 8 or 9 speed hub will still fit on a bike originally with a 7 speed? Are the overall dimensions the same?
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    7-speed cassette, spacer, and 8-speed shifter work too
    Honestly... ahh I give up
    Former Bike Wrench
    An older frame (pre 1994) will have 130mm hub spacing. New 8/9/10 MTB hubs are 135mm spaced. You can generally squeeze a newer hub into the spacing (stays have enough flex).
    Bikes since 1994, even if they came 7 speed still used 135mm spacing so its not a big deal. You just need to use a 5mm spacer behind the cassette to take up the extra space.
