Results 1 to 7 of 7
    can't remove KMC master link - 9 sp inadvertantly put on 10 sp chain
    I inadvertantly put a 9 speed KMC master link on my Shimano 10 sp chain which I've been riding for awhile and I can't remove it - will a chain tool work? other ideas? thanks! please email me: rshalit@ne.rr.com
    Nov 2008
    Did you try using a pair of long nose pliers to squeeze the links together? I'm not if KMC's fall into this but some links have a bit of a snap action when installed, and it takes a bit of force to push the links together so you can remove them.
    BTW- don't forget that you have to squeeze the links from the rollers, so the plates can slide up. Also some links require that the chain be set in a Z-bend before the links can be removed. If this applies to your link, that may be your problem. Set the link vertical with one the upper chain going right, and the lower going left, then squeeze upward to release.
    fb
    www.chain-L.com
    The key to solving any problem is to understand and address the underlying cause.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    I have a KMC link and it works just like my Powerlinks, squeeze both ends and it pops out. If yours is dirty then this action is harder to make happen. As far as a 9sp link on a 10 speed chain, not sure. The only obvious difference I can think of is the 10 speed is narrower. It wouldn't seem like that would make any difference in getting it off, but they do make different links for 8 and 9 speeds. Hmmm...
    Reputation: lew242's Avatar
    I've had three KMC missing links with their chains but I've never been able to open them with or without pliers EVER. I just use an old powerlink each time, works perfectly for me every time, even by hand on the trail. In fact I just prefer SRAM chains anyhow, but some shops go out of stock.
    Dirt Deviant
    Reputation: savagemann's Avatar
    Park makes a tool for this. I believe it is called the MLP-1.
    While it is not normally needed for most links, it does come in handy for some tough ones, such as the sram 10spd links.
    The KMC links shouldn't be too hard.
    The KMC and SRAM links are pretty tough to get undone when they are brand new, but once ridden a little bit they settle in and usually come off really easily.
    Look, whatever happens, don't fight the mountain.
    It is all about lining it up...force and pliers are not neccessary...
    The lining up can be very frustrating.
    EDR
    Jun 2005
    Am I just lucky with Powerlinks and the KMC links? I never, ever, never have any issue releasing them by hand. As a check I just walked to the garage and released my KMC on my 9speed xtr chain in 2 seconds.
    I'm always amazed at all the problems I read about. I think the biggest thing is mud/dirt in the link. I rarely if ever have that problem.
  1. XTR Chain W/ Sram Master Link
    By mtbmonk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-22-2011, 10:34 AM
  2. can't remove KMC master link - 9 sp inadvertantly put on 10 sp chain
    By rshalit in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-19-2011, 03:01 PM
  3. How to remove chain without a master pin?
    By djork in forum Tooltime
    Last Post: 12-17-2008, 12:04 PM
  4. master-link on Kmc chain
    By daddy2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2006, 11:27 AM
  5. Quick link, or Master chain link for 1/8th
    By mp29k in forum Singlespeed
    Last Post: 08-06-2005, 12:39 AM
