Results 1 to 10 of 10
    SLX
    SLX is offline
    Aug 2005
    Can't remove the big ring on cranks nuts are spinning
    I installed a 3rd chain ring on my saint cranks (the chain ring was slightly thinner) just to see how a large ring would help with my riding and decided to remove it and reinstall the bash. Except this time the bolts were stuck and they spun inside the nut that holds the chaining on. With my luck all four bolts did the same thing. Ive un-installed chain rings before but this is a first. It seemed that the chain ring bolts are alloy and the nuts are steel. I have tried holding the nut with a screwdriver on the little grove in the back but no luck.
    Any Ideas? Thanks
    Old man on a bike
    One of these works better than a screwdriver http://parktool.com/products/detail....=26&item=CNW-2
    suum quique
    Meh.
    Reputation: XSL_WiLL's Avatar
    That's what I was going to suggest. I have a Shimano one that's been banging around my parts box for years.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    yep.. the crankbolt tool is what you need...
    SLX
    SLX is offline
    Aug 2005
    Thanks everyone you guys are the best!
    I didn't realize that there was a tool for it
    caffeine dependent
    Reputation: bstiff's Avatar
    Quote Originally Posted by SLX
    Dude, it's my favorite tool: the TL-FC20. I carry one in my Camelbak just so I can refer to it by name. Here's an example of the conversation:
    Buddy: "Crap, my chainring is loose. Looks like one of the bolts loosened up!!!"
    Me: "No sweat. Here, use my TL-FC20."
    Photo from www.sheldonbrown.com:
    ...idios...
    Reputation: SteveUK's Avatar
    I'd also like to take my hat off to the TL-FC20 for being a nifty little tool. The blunt edge of a dinner knife serves (pardon the pun) as a great 'ghetto' alternative, assuming the bolt itself doesn't thread flush with the peg.
    Diogenes
    POG
    POG is offline
    Pudgy Old Guy
    The tool definitely gives you a better chance but they can still be tough to grab. I've had to awkwardly clamp the tool to the nut with vice grips so it doesn't slip. This is because I leave the chainring bolts in for years until they seize up.
    willtsmith_nwi
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    Quote Originally Posted by POG
    Try blue Loctite for to keep it glued together without the parts seizing up.
    Reputation: willis.4's Avatar
    Apr 2005
    Your bolts could be too long, if the chainring is smaller than the bash guard that I assume was on there the bolts might be spec'd for that and not a thinner ring. Thus despite how tight you get the bolts it will not properly tighten up.
    I have found if you can use your thumb or another finger to hold the nut side of the bolt up to the back of the 2nd ring you should be able to tighten the bolt until it gets tight enough where you don't need anything to hold it. It should just grip up to the back of the 2nd chain-ring. If the bolts are too long you can get a set of washers to add some thickness but that is probably the quickest cheapest solution, so you don't have to spend more money on another specialized tool that you only need to tighten 4 bolts....
    Thats my opinion and what I would do.
    Willis
