Results 1 to 5 of 5
    Can't get into large rear cog
    I have a Trek Top Fuel 9.9SSL. My rear derailleur started slipping (chain slipping off cog onto incorrect cog and back). I've adjusted it and the slipping is gone. However, I can't click into my large rear cog. Once I get to the 2nd largest cog and click to go up to the largest cog, my shifter doesn't do anything. No click. It's like the shifter thinks the 2nd to last cog is the last cog. Any ideas what else I need to adjust to get things back into alignment?
    I was able to fix this by adjusting the low adjustment guide screw.
    Reputation: Nenbran's Avatar
    Dec 2010
    Yeah, just set the low limit screw.
    You probably tweaked the hanger a little. Otherwise, limit screws rarely need adjusting. May not be enough to affect shifting, but you know what to check if the shifting isn't as smooth in a couple gears.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by rlouder View Post
    Agreed. Sounds like the hanger alignment needs to be fixed.
    mtbtires.com
  1. 3 speed rear cassette with a large range?
    By thegallery in forum Singlespeed
    Last Post: 10-09-2016, 05:13 PM
  2. Replies: 11
    Last Post: 03-31-2011, 11:44 AM
  3. 250psi Max in Rear Shock on Large ML8?
    By ejfiii in forum Maverick
    Last Post: 06-13-2009, 02:28 PM
  4. Large rear tire
    By dh_rider. in forum Downhill - Freeride
    Last Post: 07-22-2007, 10:22 AM
  5. Large rotor rear.......
    By Bikeboyhello in forum Brake Time
    Last Post: 07-16-2007, 07:59 PM
