Results 1 to 10 of 10
    Reputation: crclawn's Avatar
    Can you use a xt crankset m770 10 speed crank with a 9 speed set up in the rear
    Can you use a 10 speed crank up front with a 9 speed in the rear?
    When the **** did we get ice cream?
    Biking Like Crazy!
    Reputation: blcman's Avatar
    Yeah, I'd like to know too!
    Seems like I can get a 10 sp XT crank cheaper than the 9 sp. XT set!
    I just installed a new xt-m770 crankset and am running with an 8 speed cassette - works great, no funky adjustments issues after installing, etc.
    Biking Like Crazy!
    Quote Originally Posted by yukonfatbike View Post
    What XT 770 crank was yours?
    Price Point lists BOTH the 10sp and 9sp as XT 770.
    But I guess your point would be a 9sp crank can work
    with a 8 sp rear...so a 10sp crank can work with a 9 sp rear?
    Any info out there peeps!
    yeah, it would work. no compatibility issue with that set-up. i used almost the same set-up as yours, except it was a 10spd deore crankset..
    Reputation: wrongway's Avatar
    I've got the XT M770 10 spd crankset with a SRAM PG990 9 spd cassette. works fine.
    Quote Originally Posted by wrongway View Post
    What front & rear deraileurs & front & rear shifters are you using with those?
    Reputation: Noclutch's Avatar
    Jun 2010
    But a 9 spd chain would be needed, correct?
    I believe u would still use a nine speed chain. U would only use ten speed if u use a ten speed cog in back.
    I just picked up a 10 speed triple XT crank (dyna-sys). My setup is currently 100% 9 speed SRAM and wanted to know if I can put this crank on w/o changing anything else. The chainring says HG-X chain only, which is a 10 speed asymmetric chain.
  1. Shimano Press Fit 10 speed crank and 9 speed external cup compatibility question
    By wildh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-20-2011, 11:45 AM
  2. SRAM X.0 9-speed drivetrain w/X.0 10-speed crankset?
    By misterdangerpants in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-19-2010, 05:23 PM
  3. XT M770 10 spd V XT M770 9 speed Cranks
    By Ineedmorecowbell in forum Shimano
    Last Post: 07-31-2010, 04:20 PM
  4. single speed crank with 9spd rear? or maybe go double crank?
    By willymcd in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-30-2008, 06:50 PM
  5. crankset for 6-speed rear
    By p0werp0p in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-14-2004, 11:49 PM
