Results 1 to 2 of 2
    Mar 2005
    Can you Shave a broken tooth?
    I have some dues cranks that had a middle ring tooth that tore at a shift ramp. Upon disassembly I found a ring bolt missing in line with the broken tooth that probably didn't help. I removed the ring and Machined the tooth with a diegrinder. I left as much as I could, but I wanted to get down to where the tear started. I reassmebled it with loctite on the ringbolts and one new steel bolt for now. My question is has anybody else done this? I'm wondering if it will be fine for years to come or, only a few rides. I've put 50 miles on it and I think it shifts as good as new. Thanks
    Reputation: hurtman's Avatar
    May 2005
    You will be fine.
    You should have no problems. Just make sure that the tooth is as smooth as possible to prevent it from holding onto the chain.
    "Failing to fetch me at first keep encouraged, missing me one place search another, I stop somewhere waiting for you." W. W.
