Results 1 to 9 of 9
    Jun 2018
    Can you guys tell me what the cause for this sound is?
    My bike recently started clicking. It only happens when pedaling under power, pedaling easy it wont click, or if it does its very faint. I notice that if i pedal hard with the right pedal its quiet its only when power is applied on the left. Here is a video:
    https://youtu.be/-neJaLHNl9I
    Is it bottom bracket? Its a 2016 Jamis Dakota Sport that uses a pressfit 30 BB.
    Can you change the sound by shifting to other rear gears?
    Jun 2018
    The clicking seems to be the same in different rear gears
    Jul 2015
    Could be anything...bottom bracket is prob last thing to check, start lubing everything, pedal threads in crank arm, pivots , seat post in frame, saddle in clamps, I've run into this quite a bit and even though it always sounds like it's from BB when you're sitting on bike I've found it rarely ends up being the BB
    Sent from my XT1585 using Tapatalk
    Jun 2018
    What's a good lube/grease for the pedals and seat post and all other non chain stuff?
    Sent from my SM-G955U1 using Tapatalk
    Apr 2013
    same issue when standing and pedaling? you can most likely eliminate seat/post if it's still making the sound out of the saddle. i'd check that first then the left pedal and left crank arm to the spindle, then the BB.
    Jul 2015
    Park tool poly or Phil Wood are pretty standard
    There was a thread recently along a similar question you might want to check out. Sorry, I don't have a link.
    IME, this noise had been with pedal bearings/bushing.
    Sent from my Moto G (5) Plus using Tapatalk
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    Had a "clicking" sound on a Cannondale Caad 4 road bike, only when I rode hard. Turns out the cable stop on the down tube had some rust on the spring in the tension adjuster. When I rode hard I moved the bike side to side just enough to make it click.
    So it could be anything.
    Good luck.
  1. Replies: 25
    Last Post: 03-13-2016, 07:42 AM
  2. Replies: 4
    Last Post: 01-03-2013, 09:10 PM
  3. Replies: 11
    Last Post: 09-29-2011, 09:03 PM
  4. my pal's bike..you guys tell him..
    By punchypee in forum Bike and Frame discussion
    Last Post: 02-12-2011, 02:00 PM
Members who have read this thread: 51
