Results 1 to 5 of 5
    Can an XTR 3x9 front derailleur be used in with a new 2x10 XT setup
    So I have a year old front XTR derailleur and shifter. My GF just got a 2x10 setup using SLX and XT, is there a way to still use the front XTR shifter and derailleur on her new setup. Boh setups are similar in mounting and that won't be a problem. Tanks for any help.
    Reputation: toot334455's Avatar
    Apr 2013
    yea, just set the limit screw
    its better to shift from 2nd to 3rd, opposed to 1 to 2, cuz theyll be tension on the cable already
    It will work but not perfectly, for example I run into a problem on my fatbike, basically you can not lower the derailleur to the require "2MM gap" (with the biggest chainring) because the bottom part of the cage touches the chainstay, is actually not that big of a deal and the bike shifts fine, but been kind of a bike geek is bothersome to know is there..Can an XTR 3x9 front derailleur be used in with a new 2x10 XT setup-img_4515-m.jpg
    Thanks. I guess I'll put it on and play with it. Nothing better than tinkering.
    Reputation: Aresab's Avatar
    Using a 3X derailleur can work without issue, but you really should not lower it on the frame. The derailleur has indentations as such to push/pull the chain for each of the 3 rings, lowering it will potentially cause mediocre shifting. It may look a bit odd with the derailleur high, but in my case, shifting is spot on. Also, when I lowered mine for a test, I was getting rubbing on the outside cage where the indentation is to lower from middle to granny gear.
  1. Replies: 1
    Last Post: 07-11-2013, 06:16 PM
  2. Which XT derailleur for a standard 2x10 setup?
    By KevinGT in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-16-2013, 07:54 AM
  3. will 2x10 shimano m980 xtr front shifter work with sram xx front derailleur?
    By gideon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2012, 06:28 AM
  4. 2x10 front derailleur
    By shift96 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-01-2012, 08:27 PM
  5. X9 2x10 front derailleur setup on DW Sultan
    By trumpetinc in forum Turner
    Last Post: 04-22-2011, 04:12 PM
