Results 1 to 19 of 19
    May 2010
    Can I remove another link? pics inside.
    Hey guys im adjusting my bike since im done with the build its a 1x9. what you see is the x9 short cage derrailleur at the biggest and smallest gear. Im new to this and already removed 2-3 links. but im not sure i feel like i can still take off another 2 or at least one. Can i get some input from the pros ? thanks!!
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    great pics...
    You look to be just about right.
    You can see for sure if you bypass the derailleur and wrap the chain around the largest cog and ring and have 1 full link (two pins)+ of overlap.
    Honestly... ahh I give up
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Breitness24
    If anything, it is too short. Need to make sure it does not rip the RD off when the suspension compresses fully.
    Deflate your shock and cycle the suspension with the chain on the big cog.
    mtbtires.com
    Jul 2003
    What Shiggy said....
    if were a hard tail I'd say it was fine. But with the derailleur that extended on the big cog on an FS you'll want to check it. That is likely a bit on the short side.
    Good Dirt
    Saving lives with knives.
    Reputation: frank daleview's Avatar
    I'll second this, when I set up a chain on my full susp. bikes, I let all of the air out of the rear shock, compress the suspension all the way and then make sure I have enough for the largest combo without ripping the RD off.
    Formerly known as iceaxe
    May 2010
    ill def give it a try thanks guys.
    Reputation: saxen's Avatar
    you need to add 2 links back in, maybe more, but 2 should do it- you dont want pull like that on the RD.
    Dec 1998
    Quote Originally Posted by saxen
    If it were a hardtail, there is nothing at all wrong with pulling the RD that tight. Nothing.
    mtbtires.com
    www.derbyrims.com
    Reputation: derby's Avatar
    That looks like as short as possible without tugging the derailleur into the rear wheel - don't ask how I know
    Better check how it is with the shock's air removed and bottomed.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Looks maxed to me too. I'm a weight weenie, but this is not ok....put some links back on!
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Plays with tools
    Reputation: customfab's Avatar
    with your single pivot rear suspension your chain growth will be pretty minimal but regardless I would check to make sure. I don;t know why you would want it any shorter.
    May 2010
    well i was looking at park tools site. and they said as long as you have a bend in both cogs your good. its no where near as stretched by comparison to the site. also its 3.5 travel in the back . I only took out 3 links to begin with so I dont think id have to add or i would have a full chain length. i read that most people take out a link or 2 when going 1x9 i dunno. would it be good to even add link i thoguht i would have to buy a new chain which would be fine too.
    May 2010
    ok heres the pic fully compressed shock i actually adjusted the derailleur in the first pic to have the cog further away from the cassette.
    before adjustment
    overall view compressed.
    shifts fine. so i guess ill have to take it out to the trail. if something goes wrong i guess its a lesson learned, but at least i didnt pay to have it break. and i could live with that.
    Dec 1998
    before adjustment
    Looks OK. The only danger would be if your tried the shift onto or off of the big cog when the suspension is fully compressed.
    FYI the cogs are in the cassette. The RD uses pulleys.
    mtbtires.com
    May 2010
    hehe thanks for the correction shiggy!! lol
    Never trust a fart
    Reputation: frdfandc's Avatar
    If it was my build, I'd add another link in for piece of mind.
    But it looks ok.
    ~Disc~Golf~
    Quote Originally Posted by shiggy
    Agreed...
    Oh, and yes, they are technically 'pulleys', but if you call them "jockey wheels" you'll impress all the ladies with your superb bicycle nomenclature
    Dec 1998
    Quote Originally Posted by highdelll
    Agreed...
    Well, the top pulley is the jockey. The bottom the idler pulley.
    mtbtires.com
    ~Disc~Golf~
    I think it should be called the "highdelller-pulley"
    That's sure to score w/ the ladies - don't ya think?
